Duo Proxy Not Started
marlon.chung
The Duo Proxy is not starting on Windows 2019 server and the in the logs i see this:
There are configuration problems that need to be resolved.
2020-03-11T10:50:06-0700 [duoauthproxy.lib.log#error] The ikey value provided is invalid.
2020-03-11T10:50:06-0700 [duoauthproxy.lib.log#error] The radius_secret_1 value provided is invalid.
2020-03-11T10:50:06-0700 [duoauthproxy.lib.log#error] The skey value provided is invalid.
2020-03-11T10:50:06-0700 [duoauthproxy.lib.log#error] The api_host value provided is invalid.
2020-03-11T10:50:06-0700 [duoauthproxy.lib.log#error] The radius_ip_1 value provided is invalid.
Any idea if this is account related?
DuoKristina
The Duo application information in your authproxy.cfg's [radius_server_x] section is invalid. Double-check that information against the application details from the [Duo Admin Panel](https://admin.duosecurity.com". You didn’t mention which application or VPN you’re protecting with Duo, but here are the generic RADIUS instructions that show what the authproxy.cfg should look like and how to edit it.
Duo, not DUO.
