Duo RPM repository broken for EL9 distributions
JamesHarr74967
I was testing Duo AlmaLinux9 (RHEL 9 derivative) and found an issue with the Duo RPM registry. After getting some help from AlmaLinux community, I found out that that AlmaLinux9 (and presumably other RHEL9 derivatives) have disabled SHA1 signatures by default, which Duo uses.
I’m going a bit off the road with this one because there’s not an official Duo build for EL9 yet (hope there is). I’m actually using the EL8 builds for an EL9 distro.
The issue presents like this:
root@localhost# rpm --import https://duo.com/DUO-GPG-PUBLIC-KEY.asc
error: https://duo.com/DUO-GPG-PUBLIC-KEY.asc: key 1 import failed.
The work-around is pretty straight forward:
root@localhost# update-crypto-policies --set DEFAULT:SHA1
To return the system to a normal state:
Additionally, you need to install compat-openssl11 so pam_duo.so will work
root@localhost# dnf install -y compat-openssl11 duo_unix
The true fix is to update the repository signature keys to use SHA256 instead of SHA1, as well as producing a build for EL9 systems. Unfortunately that means rolling the keys. If Duo/Cisco has plans to do so, I’d like to know since this is a disruptive thing.
In the meantime, I hope this helps others.
References:
DuoKristina
Thanks for letting us know about this. We will roll the key tomorrow to SHA512 with the next Duo Unix release.
Heads-up: GPG key for Duo Unix will be updated June 2, 2022
Editing response to mention 1.12.1 release is out with CentOS Stream 9, RHEL 9, and Fedora 34 packages.
Duo, not DUO.
DuoKristina
Duo, not DUO.
Thanks, you managed to solve two of my problems in one shot. The move to SHA256 and official RHEL9 support (which means Alma9 is supported)
Thanks for your post! It helped us address the signature issue before the release.
Duo, not DUO.
