Duo & Sonicwall TZ - 6 digit code works, but not getting push
rtimmons
I’ve got Duo configured and working with a Sonicwall TZ firewall. Users can get synced over LDAP & login using their domain password. Using NetExtender, user can login and get prompted to put in the 6 digit code. Then they get logged onto the VPN.
I’m trying to understand why it’s prompting for the code rather than simply pushing to the mobile device.
My config:
[main]
test_connectivity_on_startup=true
debug=true
[ad_client]
host=(IP Address)
service_account_username=serviceaccountname
service_account_password=serviceaccountpassword
search_dn=dc=sample,dc=local
ikey=IKEY
skey=SKEY
api_host=APIHOST
[ldap_server_auto]
port=xxx (nonstandard LDAP port)
ikey=IKEY
skey=SKEY
api_host=APIHOST
client=ad_client
failmode=safe
exempt_primary_bind=false
Amy2
Level 5
Level 5
Hi there! For Sonicwall TZ, you should use our generic RADIUS instructions, and be sure to configure the proxy for Active Directory/LDAP as your primary authenticator. @DuoKristina shared more info on this particular configuration in a past answer here, so I suggest checking that topic out for details. I hope that helps!
Edit: oh, and let us know if you have other questions. I’m not an expert on this topic, but perhaps others can weigh in.
