Duo SSO for AWS and CLI needs a browser?
RubenCardenal
I'm reviewing the KB article at https://duo.com/docs/sso-aws-cli
Seems to imply that to proceed with SSO a browse window will be opened in order to authenticate the SSO login.
The problem with this is that absolutely won't work with consoly-only based login attempts.
Is there any alternative? I know for sure that this can be done, I just don't know if Duo supports it.
Use cases:
  • Executing a script/command that prompts for the 2FA number, being that provided by the Duo app. Yes, we already have this, but I want it linked to the IdP Duo is tied to (Google Apps) so when we delete or block an user in Google, that user will stop being able to authenticate via CLI.
  • Optionally, requiring a fingerprint in the mobile device or an auth prompt sent by push to the mobile device
Does Duo support this? I know this can be done. but I want to know if it can be done with Duo or not.
Currently we're on an Essentials plan with 175 users. And I need to know if Duo is the right path for us.
Thanks.
DuoKristina
Today all Duo SSO SAML logins require passive web authentication within a browser window.
You may stumble across solutions like this, which try to scrape the web page for a console-only login with MFA. This approach is not supported by Duo (as noted here) and not guaranteed to work.
Some people add Duo to AWS directory via RADIUS (quick start), which can work for true console-only access.
Duo, not DUO.
