Duo sso with umbrella integration
I am trying to integrate duo sso with cisco umbrella
  1. can I use AD as my authentication resource?
  2. where do I upload the metadata file that I downloaded from cisco umbrella
I managed to upload the metadata file I downloaded from the duo admin panel but I cant find the place to upload the file i downloaded from umbrella page.
We couldn’t validate your configuration. Please try again. I get this error when I test the configuration.
BabbittJE
What package(s) did you install, e.g., Duo for Remote Desktop Gateway, etc., and what instruction(s) did you follow? I don’t think anyone can help without knowing what setup you have and what you tried to install/do.
And, yes, Duo can use Microsoft Active Directory as an authentication source. My setup does. I use Duo’s RDG and SSO for that.
DuoKristina
Hi @rahel ,
Did you follow these instructions for SSO with Umbrella? Duo Single Sign-On for Cisco Umbrella | Duo Security
You download an XML metadata file from Duo to upload to Umbrella, but you do not upload an XML file from Umbrella to Duo.
Duo, not DUO.
