Duo Unix Package Debian 9 - apt update failed
gh0-0st
In order to install DUO UNIX with packages for Debian 9, I followed the information given in Duo Unix - 2FA for SSH with PAM Support (pam_duo) | Duo Security
But when you try to run apt update, the following errors appear:
# apt-key list
pub dsa1024 2013-09-05 [SC] [expire : 2020-08-22]
30BF E024 2B19 592E B122 211D 1CC9 1FC6 15D3 2EFC
uid [ inconnue] Duo Security Package Signing dev@duosecurity.com
sub elg4096 2013-09-05 [E] [expire : 2020-08-22]
# apt update
Ign :9 http://pkg.duosecurity.com/Debian stretch InRelease
Réception de :11 http://pkg.duosecurity.com/Debian stretch Release [2 046 B]
Réception de :12 http://pkg.duosecurity.com/Debian stretch Release.gpg [72 B]
Ign :12 http://pkg.duosecurity.com/Debian stretch Release.gpg
W: Erreur de GPG : http://pkg.duosecurity.com/Debian stretch Release : Detached signature file ‘/var/lib/■■■■_Debian_dists_stretch_Release.gpg’ is in unsupported binary format
E: Repository http://pkg.duosecurity.com/Debian stretch Release is not signed.
Has anyone ever had a similar issue?
If so, how did you fix it?
Thank you for your help in solving this problem.
Xander_Desai
I just ran a quick test of this and it worked okay for me so my hunch is it might be something going on locally.
The expiration looks good on your key as well, but maybe running
curl -s https://duo.com/APT-GPG-KEY-DUO | sudo apt-key add -
followed by a sudo apt-get update
would be worthwhile just to double check.
gh0-0st
Thank you for your answer,
but i retry and same issue:
OK
# apt-key list
/etc/apt/trusted.gpg
uid          [ inconnue] Duo Security Package Signing <dev@duosecurity.com>
# apt-get update
W: Erreur de GPG : http://pkg.duosecurity.com/Debian stretch Release : Detached signature file '/var/lib/■■■■_Debian_dists_stretch_Release.gpg' is in unsupported binary format
E: Le dépôt http://pkg.duosecurity.com/Debian stretch Release n'est pas signé.
Perhaps because i used Debian “Buster” and not “Stretch”?
I don’t really understood why that’s failed.
If no idea then I will try with source files and compilation.
Briar_Scott
Thank you for your issue. We have just released an update to duo unix that should fix this problem.
You will need to update your GPG key before trying to update again. Please follow our duo unix docs to update your GPG key.
We have also made a community post that has a bit more information about updating your key.
