Exchange 2016 with .NET 4.7
stanthewizzard
Hello
the last CU for exchange is not compatible with DUO.
When do you think that you will update your installer to .NET 4.7
PatrickKnight
Hey @stanthewizzard the Duo OWA integration is supported with CU10 and .NET 4.7.
Could you share what issue you are encountering?
stanthewizzard
Manage to install it
removed previous version
reinstalled it with elevated prompt
