Fedora 34 - Install duo_unix from repo
javaripa
I’m interested in installing the duo_unix package in my Fedora 34-35 installations.
Is there any specific repo I can use?
Unfortunately the default RHEL repo
https://pkg.duosecurity.com/RedHat/$releasever/$basearch
does not apply to the Fedora installations (tried with Fedora 34:
Status code: 404 for https://pkg.duosecurity.com/RedHat/34/x86_64/repodata/repomd.xml
Amy2
Level 5
Level 5
Hi @javaripa, most Fedora installs are similar to CentOS, so I recommend using that. Starting in Fedora 33, there was a change to the way public key authentication is handled. Some people have had success adding PubkeyAcceptedKeyTypes=ssh-rsa to their ssh config folder. Please see this Reddit post for more details. I hope that helps!
