How long of a delay before moving to next radius_client?
kmanning1
We use DUO as our MFA for Cisco Anyconnect and it’s been working without issue. I am using RADIUS authentication for this. In the documentation and knowledge base I saw that you can list multiple radius_client sections and matching radius_server_auto sections. I am wanting to add a second and third radius_client. My question is, if the first [radius_client] goes down and someone tries to log in then how long does the auth proxy wait before moving on to the second [radius_client2] ? I saw an optional timeout command for [ad_client] but nothing like that for [radius_client]. Any help would be appreciated!
DuoKristina
It will never move on. You can only specify one radius_client or ad_client section in a server section. The *_client sections are independent; there is no failover between.
What you actually want is to add backup hosts to your single radius_client section, like…
[radius_client]
host_1=1.2.3.4
host_2=1.2.3.5
secret=bothhostsmustusethesamesecret
With that config, then if host_1 doesn’t respond then it will move on to host_2.
This configuration is described in the Authentication Proxy reference section for radius_client.
Duo, not DUO.
DuoKristina
[radius_client]
host_1=1.2.3.4
host_2=1.2.3.5
Duo, not DUO.
Hi Kristina,
I would like to know how is the behavior of the Authentication Proxy regarding backup servers. Are the hosts declared dead for a period of time, how long are they declared dead? connections will be attempted every time?
Thanks for your comments.
What kind of backup servers?
If you mean a list of RADIUS or AD hosts in the radius_client or ad_client config sections, the proxy will try the hosts in the order listed at every auth. It does not mark a host as failed and then not use it anymore.
Duo, not DUO.
