Bookmark
Subscribe
1669
Implement DUO for an application that can't natively implement MFA
fhikrisuryadi
Hi Guys, I need to know, if there is an application that cannot natively implement MFA, is it possible to implement MFA Number Matching to the server/apps using DUO Cisco with absolutely no changes from the application side? for example the type of application is Virtual Application and connected to Active Directory for checking credential. Please also provide information about whether MFA number matching is built into DUO or can also be integrated with AzureAD/EntraID for the MFA Number Matching.
9 Replies 9
DuoKristina
Not a guy but happy to respond anyway to suggest that if your application supports SAML 2.0 or OIDC you may be able to use Duo Single Sign-On to put Duo Universal Prompt with verified Duo Push (our implementation of number matching) in front of your application with no code changes.
Also, if your application is already using Entra ID (formerly Azure AD) for authentication you might also be able to use Duo's custom control for Entra ID conditional access. This also supports Duo Universal Prompt with verified Duo Push.
Duo, not DUO.
fhikrisuryadi
Hi Kristina, Thank you for your answer. So if i want to implement MFA Number Matching to my application without code change, the application must supports SAML 2.0 or OIDC, right?
That it is correct, it must support SAML for it to work with Duo or any IdP in general.
Please mark this helpful if you are happy with the response.
For apps on prem where you're not doing SAML, you can get Duo 2factor the app is LDAP or Radius using an authentication proxy..  you can't get the number matching from a proxy though...
i'm sorry Ken, I can't fully understand your argument. can you explain more clearly? Thank You
1. What you refer to as "number matching" is represented in our service as "verified Duo Push".
2. Verified Duo Push is ONLY available in the Duo Universal Prompt experience.
3. Duo Universal Prompt is ONLY available during interactive browser authentication (therefore excluding Duo RADIUS or LDAP configurations, which is what Ken was pointing out).
4. There are four ways to get a browser-based Universal Prompt in front of your application:
     a. Implement authentication via our OIDC authentication endpoints in the code of your application with our Web SDK.
     b. Implement authentication via direct use of our OIDC authentication endpoints in the code of your application.
     c. If the application supports SAML 2.0  or OIDC federation already, put Duo SSO (which supports Duo Universal Prompt) in front of it. Duo SSO is available in all paid Duo plans.
     d. If they application doesn't support SAML and is on-premises, publish it via Duo Network Gateway (which supports Duo Universal Prompt). Duo Network Gateway is only available in the Duo Premier plan (as in, the most expensive Duo plan).
You want "absolutely no changes from the application side", which to me means "no custom code updates to our application". That excludes methods a and b, so the next best option is c.
Duo, not DUO.
Kristina covered it...
________________________________
This email is intended solely for the use of the individual to whom it is addressed and may contain information that is privileged, confidential or otherwise exempt from disclosure under applicable law. If the reader of this email is not the intended recipient or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
If you have received this communication in error, please immediately notify us by telephone and return the original message to us at the listed email address.
Thank You.
gabriel garciaf
Hi Guy
Cisco DUO have 2 options to do the MFA, SAML and AD, you can use SSO and some universal prompt if the technology not appear in the bar protect technology.  one time i configure a technology that not support MFA and can integrate with the matching numbers, but the only request is that needed to be integrated with AD to obtain the profile the user that goin to connect
DuoKristina
Someone liked my earlier response today which caused me to take another look. Since 2024 we've made some changes to verified Duo Push so I'll describe them here for anyone who finds this thread in the future.
1. Verified Duo Push is now an option for Auth API v2 integrations, meaning you can now extend this to your custom apps that don't support SSO or can't show an interactive browser prompt via Duo Web SDK or OIDC
2. We've extended verified Duo Push fill options so your users don't have to just type in codes. Now they can use Bluetooth to automatically fill in the verification code or perform verification over BLE proximity without any verification codes at all.
Duo, not DUO.
