Is it possible to use Duo Authentication for MacOS with Apple Remote Desktop?
thanne
The documentation only mentions console access, so it seems like the answer is probably no, but I’d like to confirm. I’d like to set up Apple Remote Desktop and require Duo for remote login using that service.
mkorovesisduo
Level 4
Level 4
Hi Thanne, no, our integration with macOS does not protect remote logons at this time. If you’d like to create or be added to a feature request for that, please contact your Duo representative or Duo Support.
thanne
Thanks! I’ve now done so.
