Meraki Duo SSO through SAML
CDragna
I'm tryign to set up Duo SSO for Meraki Client VPN, the knowledgebase seems out of date as it refers to choosing the Applciation Protect page when currently it's meant to use SAML. I have a few items I am not 100% sure where to get
1) I think the entity ID should be https://hostname-specific.dynamic-m.com/saml/sp/metadata/SAML, is that correct?
2) What do I put in for Single Sign-On URL?
3) I'm using the self generated certificate for Meraki VPN, how do I download this to upload to Duo?
Thanks!
--Chris Dragna
DuoKristina
Are you using these instructions? https://duo.com/docs/sso-meraki-secure-client
Duo, not DUO.
CDragna
Thank you for the reply, but the issue was I was attempting to use the built in Merkai Cloud Authorization with Duo. This is not compatible with SAML it turns out.
