Meraki SAML Login through DAG with Active Directory
sajidabbas
I’ve been trying to configure Meraki SAML login to work with DAG SSO Launcher, using it with Active Directory as primary authentication.
I’ve configured according to the documentation available for Meraki SAML login. However i do get the MFA push prompt but then login doesn’t work.
After checking login history and error on Meraki dashboard it says, ‘Assertion contains no username’. A deeper look shows the username attriute does not seem to be pushed even though documentation says Active directory attribute is being mapped.
Has anybody set this up using Active Directory. Any help would be appreciated.
Sajid
DuoKristina
Did you add mail,distinguishedName to your AD configuration mentioned in the documentation? We map the source attributes to the IdP automatically, but you need to specify which source attributes to send.
Duo, not DUO.
