Microsoft RRAS with Duo Mobile problem
Fred06
Hi everyone,
I’m testing to set up MFA with DUO Mobile on my VPN server.
Everything works with a normal SSTP connection.
Here is my configuration :
1x : Windows 2019 server : RRAS with (SSTP protocol) (10.10.10.22)
1x: Windows 2019 server: NPS/Radius (10.10.10.23)
1x: Windows 2019 server: Duo Proxy service (10.10.10.24)
When I try to connect my VPN client, I get the following messages in the logs:
2020-11-10T16:57:51+0100 [duoauthproxy.lib.log#info] Duo Security Authentication Proxy 5.1.0 - Init Complete
2020-11-10T16:57:51+0100 [-] RadiusClient starting on 55744
2020-11-10T16:57:51+0100 [-] Starting protocol <duoauthproxy.lib.radius.client.RadiusClient object at 0x000001957A1563D0>
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] Sending request from 192.168.68.22 to radius_server_auto
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] Received new request id 4 from ('192.168.68.22', 52047)
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] (('192.168.68.22', 52047), fidmc\mdm-user1, 4): login attempt for username 'fidmc\\mdm-user1'
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] Sending request for user 'fidmc\\mdm-user1' to ('192.168.68.23', 1812) with id 38
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] Got response for id 38 from ('192.168.68.23', 1812); code 3
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] (('10.10.10.22', 52047), fidmc\mdm-user1, 4): Primary credentials rejected - No reply message in packet
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] (('10.10.10.22', 52047), fidmc\mdm-user1, 4): Returning response code 3: AccessReject
2020-11-10T16:58:30+0100 [duoauthproxy.lib.log#info] (('10.10.10.22', 52047), fidmc\mdm-user1, 4): Sending response
Here is my authproxy.conf file:
[radius_client]
host=10.10.10.23
secret key=XXXXXXXX
pass_through_all=true
[ad_client]
host=10.10.10.10
service_account_username=FIDMC\Administrateur (for test)
service_account_password=mypassword
search_dn=DC=fidmc,DC=ch
security_group_dn=CN=AOVPN_Users,OU=GROUPS,OU=MCH,DC=fidmc,DC=ch
[radius_server_auto]
ikey=my_ikey
skey=my_skey
api_host=my_api_host
radius_ip_1=10.10.10.22
radius_secret_1=radiussecret1
failmode=safe
client=client_radius
port=1812
I also get error 812 in the client’s Event Viewer.
Does anyone know where the error could come from?
Thank’s in advance.
Amy2
Level 5
Level 5
Hi @Frederic_Viatte, just a heads up that I edited your post to remove your secret key and RADIUS secret. These are unique to your application and account and should be kept private. They should never be shared publicly
I noticed in your config file under [radius_server_auto] you have the client listed as client=client_radius when it should be radius_client instead. Try fixing that and see if it resolves the issue!
Something else I looked into was the error code Primary credentials rejected - No reply message in packet in your AuthProxy log. This help article says to set pass_through_all=true under radius_client to resolve this. However, I see in your config that you have done so already, so that shouldn’t be a problem.
Give my suggestion a try, and if you’re still encountering trouble, I recommend reaching out to Duo Support for further troubleshooting and help.
Fred06
Thank you for your quick response!
Thanks for correcting the post, I’ll know for next time
Then indeed the radius_client line was already configured right. I made a mistake in the post.
Here is a quick schematic of the current configuration.
Hopefully it will help to solve the problem.
Thank’s in advance.
