RADIUS with multiple "clients"
albinon1nja
We currently have a RADIUS setup for our SonicWall SSL VPN as well as our Amazon Workspaces environments. Right now, they are pointing to a single RADIUS client, which is our main domain controller. For redundancy, I would like to add in a second RADIUS client for our backup domain controller and hopefully have it round robin between the two for failover purposes. Before I test this out, is it possible? If I just label both with the same [radius_client] name, will it just choose one or the other?
Thanks in advance!
DuoKristina
You cannot configure round-robin within the authproxy.cfg file.
You can add additional primary authentication hosts in radius_client by specifying them as host_2, etc. If the Duo proxy can’t contact the firt host, it will try the next one.
This is documented here.
Note that all hosts specified in radius_client must use the same secret.
You mention that your primary auth server is your domain controller. Are you actually using ad_client? Just like radius_client, you can add additional host_2, host_3, etc. entries for failover hosts. Unlike radius_client, the ad_client hosts don’t use a shared secret, but do need to accept the same service account username and password.
If you really want round-robin, you can create a DNS entry or virtual IP that points to multiple primary authentication servers, and then use that hostname or VIP in your authproxy.cfg ad_client or radius_client section as the host.
Thanks for trying Duo!
Duo, not DUO.
DuoKristina
Duo, not DUO.
