RD Gateway Caps and Raps Restore?
simon71
I know if you deploy DUO on your rd gateway server it installs the 2.2 plugin and removes your CAPs and RAPs from a windows deployment . It actually removes the functionality from the server manager MMC snapin.
How do you get those back if you wish to? Can you simply uninstall Duo to return those items or are they gone for good?
Dooley
Level 3
Level 3
Uninstalling will indeed restore CAPs and RAPs. If you need to uninstall, please follow the instructions here: https://help.duo.com/s/article/1431 to do so.
Dooley
Level 3
Level 3
