Duo not support MFA for Stash atlassian?
TheZealous
Hello everyone,
I have 2 questions:
  1. Do you know if when Duo will be support for Stash, Atlassian product?
  2. Since DUO is not an option for stash right now, I was thinking lets use ADFS for Stash (…mind blowing… right?..) Please look at this document : https://confluence.atlassian.com/enterprise/adding-saml-integration-to-your-existing-user-management-infrastructure-861244976.html
Does anyone in here think that this option with ADFS will work? Any suggestions?
TZ
TheZealous
Just a quick update… I use SAML with Okta instead of ADFS and it worked.
