Remote Desktop Connection Manager on server with Duo - "Ordinal not found"
gmtexx
We installed Microsoft’s Remote Desktop Connection Manager on a terminal server with Duo authentication installed so we can RDP into other servers from that box. Everything worked great until we rebooted the server, and now every time we try to make an RDP connection to another server using RDCMan, we get this error message multiple times:
“The ordinal 379 could not be located in the dynamic link library C:\Program Files\Duo Security\WindowsLogon\DuoCredProv.dll”
If you click through the multiple warnings RDCMan connects to the remote server,
Anyone seen this before? Any way to resolve it?
Thanks.
35 Replies 35
wayneaw
Just noting that I have Server 2016 with 3.1.2 installed and am still getting the ‘ordinal 381’ error. I get it with RDCMan or with a straight RDP session when I run an application on the remote session as an administrator.
reid_g
We are planning to roll out Duo to several hundred additional servers but our engineers are pushing back due to this bug. Is there an update or possible timeline for a fix for this issue?
jshakespear
[Update] I tried version 4.0.0 and it is still giving the error, so it has not been fixed. . .
I just installed version 4.0.0 today, and so far, things are looking fixed when I try to connect using Terminals.
Is there a resolution for this that does not involve saving credentials in RDCMan?
rohmcd
This is affecting my team as well. @PatrickKnight can you at least give an update regarding the priority review you mentioned nine months ago?
IanO
We’re seeing the same issue here on machines running mstsc against Windows 2016 servers.
As the issue has been around for 9 months and several DUO releases, is there a fix in the pipeline ?
Not a good initial customer experience for my staff !
Johnno888
Hello, we are getting this error when attempting to use Virtual Machine Manager attempting to connect to virtual machine’s consoles on other domains.
FrankS1
Just to confirm this is still a problem. I even tried to save the profile over again and it still pops up twice on each connection.
a1ex1
Same issue for us (using ASG 2019 x64) with the latest Duo version (4.0.3).
Any idea when it’s likely to be fixed?
Patrick_Cooley
I was doing a Google search cause I was running into the same issue. I’d like to add my two cents that I believe could be useful. I’m noticing a trend that briefly reading through the previous comments I don’t think has been pointed out yet. Maybe just an issue w/ the remote clients that run Windows 10?
  • Same error Ordinal not found.
  • Host is using Windows Server 2016
  • We use Dou to access the host.
  • What I’ve noticed…
    — Is that the clients running Windows 7 Enterprise are not affected by this.
    — However remote clients running Windows 10 Enterprise are affected.
Hope this helps!
tlamming
Hi, was this ever fixed? running into this with Remote desktop connection manager.
PatrickKnight
Hey y’all quick update. We’ve identified the issue and a fix will be included in the next release, release date TBD but I’ll post here again with an update as it gets closer to release.
After over a year I resigned myself to this never getting fixed. Glad it finally made it to the release schedule! Thanks for the update.
We had the same issue and we found that by inheriting credentials from parent from the logon credential tab was fixing the issue.
But I must admit that it’s less secure
PatrickKnight
We’re targeting the end of the quarter to have new release out that will resolve the ordinal issue.
