Remote Desktop Published Apps Prompt Duo Twice
msitcmatt
Dear All,
I have recenlty built a RDS server with soem published apps. The App and Duo works but I am getting two Duo pushes. I have installed duo-rdgateway and dup-win-login and the apps dont work if either one is uninstalled , only work with both installed. Is there anyway around the two duo pushes?
TIA
Matt
0 Replies 0
