Security Agent Not Running - Crowdstrike Falcon
Hello All!
We’ve recently implemented DUO MFA/2FA into our environment. Currently, we are using Crowdstrike Falcon for our AV solution.
In a small number of Windows 10 endpoints, we are seeing the DuoDeviceHealth app state that the security agent is not running, when CS Falcon is indeed running on the endpoint and checking into the Falcon console. This is preventing users from accessing necessary everyday resources.
Has one one else run into this issue and can offer some advice?
rrr
hi All, i had similar issue, i hope it will help ( it helped for me) : 1) uninstall the old one and install the newest version of Duo https://dl.duosecurity.com/DuoDesktop-latest.msi2) go to the system settings and restart the service duo desktop update service ( to get there you can use command prompt type services.msc) 3) restart your laptop - should work
