Several duo push notifications
Exonix1
we are using Duo with RRAS 2012 R2.
When user are connecting, then he may receive more than one Push notifications.
I think that user has very short time to confirm an authentication.
is it possible to increase the time for answer?
DuoKristina
The Duo Push timeout is 60 seconds. Did you increase the RRAS timeout to match? See her: https://duo.com/docs/rras#change-the-rras-authentication-settings.
Duo, not DUO.
DuoKristina
Duo, not DUO.
thank you!
i changed to 15 sec. it works perfect!
