Unable to establish connection between Radius and Duo Proxy
rockyyy
DuoProxy is unable to establish a connection with the Radius Server.
I am using windows 2012 as a Radius Server and following is the Authproxy.cfg and find the connectivity_tool.log as below.
[main]
debug=true
[radius_client]
host=1.1.1.1 (Radius Server IP)
secret=password (Radius Server Password)
[radius_server_auto]
ikey=000000000
skey=00000000
api_host=■■■■■■■■■■■■■■■■■■■■■■■■
radius_ip_1=1.1.1.1
radius_secret_1=password
failmode=safe
client=radius_client
port=1812
[info] Testing section ‘main’ with configuration:
[info] {‘debug’: ‘True’}
[info] There are no configuration problems
[info] -----------------------------
[info] Testing section ‘cloud’ with configuration:
[info] {‘api_host’: ‘■■■■■■■■■■■■■■■■■■■■■■■■■■■■’,
‘debug’: ‘True’,
‘ikey’: ‘000000000000000000’,
‘skey’: ‘[40]’}
[info] Testing section ‘radius_client’ with configuration:
[info] {‘debug’: ‘True’, ‘host’: ‘1.1.1.1’, ‘secret’: '
[info] Testing section ‘radius_server_auto’ with configuration:
‘client’: ‘radius_client’,
‘debug’: ‘True’,
‘failmode’: ‘safe’,
‘port’: ‘1812’,
‘radius_ip_1’: ‘1.1.1.1’,
‘radius_secret_1’: ‘’,
‘skey’: '
[40]’}
[info] There are no connectivity problems with the section.
‘debug’: ‘True’,
‘skey’: ‘[40]’}
[info] The Cloud connection has no connectivity problems.
[warn] The RADIUS Client section has connectivity problems
[error] We cannot confirm that the Auth Proxy was able to establish a RADIUS con
nection to 1.1.1.1:1812. In the case of an actual failure this may be due to
a misconfigured secret or network issues. This may also happen if the upstream R
ADIUS Server does not support the Status-Server message
[debug] Exception:
‘debug’: ‘True’,
‘failmode’: ‘safe’,
‘port’: ‘1812’,
‘skey’: '
[40]’}
[info] The RADIUS Server has no connectivity problems.
[info] SUMMARY
[info]
[info] Section [radius_client]
[info]
Amy2
Level 5
Level 5
Hi there khurramjn,
Please contact the Duo support team for help with your issue!
You’ll find more information about how to get support here.
