LDAP Proxy for Solarwinds N-Central
eperson
Hello, does anyone have experience configuring the DUO LDAP proxy to work with Solarwinds N-Central? I was able to get it working, but I had to set the account used to query LDAP to permanently bypass DUO 2FA. Is that the only way to do this? I don’t like the idea of creating an insecure account to get it working.
Thanks!
Amy2
Level 5
Level 5
Hi there,
If you use the exempt_primary_bind and exempt_ou options shown in the LDAP Auto section of the Duo Authentication Proxy Reference, you will not need the user in bypass. You can find more information on this in a past community post here. Let us know if you have any other questions!
