Universal Prompt - Disable Auto Push?
JuniorSA
Is there any way to disable auto push for the Universal Prompt? This is the only thing stopping me from switching over to it.
In my scenario we have several 2FA Devices using the same account and we need the option to select our own 2FA device when authenticating.
DuoKristina
Not currently. Please contact your Duo Care customer success manager or Duo account exec to add support for this as a feature request (or contact Duo Support to do this if you don’t have a dedicated rep).
Duo, not DUO.
Gigawatt
I think you can just switch back to the old default method. Unless Duo is going to end up taking that away sometime soon.
