Unix & SSH: Recieve "Skipped Duo login for 'my account':
FrankieDN
I’ve installed login_duo on my test Ubuntu 16.x box.
Installed with no issues.
When I go to test as a regular local user, by manually running /usr/sbin/login_duo on the CLI, I get the following - 4] Skipped Duo login for ‘my account’: Allowing unknown user -
Not sure exactly how to resolve.
Any advice would be much appreciated.
Frank
DuoKristina
Sounds like you’ve got your new user policy set to allow access to unenrolled users without 2FA. Either enroll the user in Duo with an authentication factor using one of the administrator methods described here, or change the policy applied to your Duo Unix application to require enrollment for unknown users.
Duo, not DUO.
DuoKristina
Duo, not DUO.
