VMWare Vsphere 6.7
dalton.humbert
We are trying to integrate Vsphere 6.7 with Duo for 2FA. Is there an article I was just not finding of how to configure this? Thanks
mkorovesisduo
Level 4
Level 4
Hey Dalton, stealing the wording of a post from one of my coworkers in another thread that touched on vSphere:
We don’t recommend or support Duo MFA with vCenter [or vSphere] SSO because we found that in some vCenter configurations it’s trivially easy to bypass two-factor.
jbgorrie1
The thread is a good resource. I had a case with Vmware and they agreed if you do not use integrated AD but ldap auth then no one could use the “bypass” and then it all went through the DUO proxy.
I’ve got it in our testing and soon production environments and it is fine.
