When Installing Duo: Connection to Duo failed
Hello! I have to install Duo in some network hosts, and we are getting an error in the first step installing it, when it checks for the connection to the DUO API… I have no problems to connect via browser to https://■■■■■■■■■■■■■■■■■■■■■■■/auth/v2/ping, but have problems to connect via DUO Install file.
We have a web proxy and is enabling the connection, we see it OK on logs, we are installing the latest version of Duo 3.1.2 on Windows 2012 R2, and configured the web proxy on regedit, we have installed OK on some other same servers of the same and other networks as well, and don’t figure out why this error now on the connection.
Using web browser (configured with same proxy as Duo uses) I successfuly connect to https://■■■■■■■■■■■■■■■■■■■■■■■/auth/v2/ping
And in logs DuoInstallTest the Log generated in the installation this says that can’t connect tho that api:
2018 ago. 21 15:51:47.660 0x00000D60/001 ** Logging started
2018 ago. 21 15:51:48.192 0x00000D60/001 Calling https://■■■■■■■■■■■■■■■■■■■■■■■/auth/v2/ping GET with no parameters (no signature)
2018 ago. 21 15:51:48.754 0x00000D60/001 Proxy: Not Configured
2018 ago. 21 15:51:49.947 0x00001370/005 Exception WebException occured: Error ConnectFailure: No es posible conectar con el servidor remoto
2018 ago. 21 15:51:49.978 0x00001370/005 en System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
en Duo.ClientBase1.AsynchronousRequestReader.ResponseHandler(IAsyncResult currResultResponse) 2018 ago. 21 15:51:50.288 0x00000D60/001 Exception WebException calling RetryableMethod method: Error ConnectFailure: No es posible conectar con el servidor remoto 2018 ago. 21 15:51:50.288 0x00000D60/001 en System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) en Duo.ClientBase1.AsynchronousRequestReader.ResponseHandler(IAsyncResult currResultResponse)
en Duo.Util.RethrowExceptionSameStackTrace(Exception exceptionToRetrow)
en Duo.ClientBase1.CallDuoEndpoint(String endpointPath, DuoWebMethod webMethod, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride, Boolean& cancelled, Stream& responseStream)
en Duo.ClientBase1.CallDuoEndpoint[ResultType](String endpointPath, DuoWebMethod webMethod, Boolean& cancelled, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride)
en Duo.ClientBase1.CallDuoEndpoint[ResultType](String endpointPath, DuoWebMethod webMethod, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride)
en Duo.ClientBase1.GetServiceTimeUtc(UInt32 timeoutOverride) en Duo.ClientBase1.CheckUpdateServerTime(UInt32 timeoutOverride)
en Duo.Authentication.RawClient.IsServiceLicensed()
en Duo.Authentication.Client.RetryableMethod[T](Func1 apiCallToRetry, Int32 noRetries, FailureToResultTranslator1 translateFailureToResult)
2018 ago. 21 15:51:50.288 0x00000D60/001 Exception WebException occured: Error ConnectFailure: No es posible conectar con el servidor remoto
en Duo.ClientBase1.AsynchronousRequestReader.ResponseHandler(IAsyncResult currResultResponse) en Duo.Util.RethrowExceptionSameStackTrace(Exception exceptionToRetrow) en Duo.ClientBase1.CallDuoEndpoint(String endpointPath, DuoWebMethod webMethod, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride, Boolean& cancelled, Stream& responseStream) en Duo.ClientBase1.CallDuoEndpoint[ResultType](String endpointPath, DuoWebMethod webMethod, Boolean& cancelled, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride) en Duo.ClientBase1.CallDuoEndpoint[ResultType](String endpointPath, DuoWebMethod webMethod, Dictionary2 parameters, Boolean secureCall, UInt32 timeoutOverride) en Duo.ClientBase1.GetServiceTimeUtc(UInt32 timeoutOverride)
en Duo.ClientBase1.CheckUpdateServerTime(UInt32 timeoutOverride) en Duo.Authentication.RawClient.IsServiceLicensed() en Duo.Authentication.Client.RetryableMethod[T](Func1 apiCallToRetry, Int32 noRetries, FailureToResultTranslator1 translateFailureToResult) en Duo.Util.RethrowExceptionSameStackTrace(Exception exceptionToRetrow) en Duo.Authentication.Client.RetryableMethod[T](Func1 apiCallToRetry, Int32 noRetries, FailureToResultTranslator1 translateFailureToResult) en Duo.ClientBase1.<>c__DisplayClass8a`1.b__89()
en Duo.Util.DoNothrow(Action unsafeLogic)
2018 ago. 21 15:51:50.397 0x0000032C/002 ** Logging shutdown
What else besides network traffic / firewalls or web proxy could we check to know why the packages do not arrive or the connection terminates unexpectedly in the first step of the Duo installer?
Thanks in advance!
mkorovesisduo
Level 4
Level 4
Hi Guillermo, please contact Duo Support for help with your issue.
