Wrong password entered by still goes to DUO Auth?
vmurali
I am entering a wrong password for the user but it still goes to DUO MFA push and then fails.
Can we not check the correct password in first step?
mkorovesisduo
Level 4
Level 4
Hi, that sounds odd. Are you sure you are entering the password incorrectly? In any case, I would recommend contacting Duo Support, describing the issue, and letting them know which application you are integrating Duo with.
