Yubikey for VPN connection
ShelBytes
I'd like to know if we can use an yubikey for a VPN connection ? As we can do for a RDP connection.
Thanks !
DuoKristina
Yes, if you are using a YubiKey to generate passcodes for Duo Windows Logon you can also use the YubiKey passcode to log into a Duo-protected VPN.
If your VPN is configured with the Duo Authentication Proxy and RADIUS or LDAP then you can append the YubiKey OTP to the submitted password after a delimiter character (default is a comma), like password,cccccciduegtucgnufcccghdjcndfoovvgrgekjiglef
If your VPN's Duo configuration shows the Duo MFA prompt in a browser (like if you have set your VPN up with Duo SSO), then you would select the YubiKey token option in Universal Prompt or use the "Enter a passcode" field in traditional Duo Prompt and tap the YubiKey to generate the passcode.
You also have the option of using a FIDO2-compatible YubiKey as a WebAuthn roaming authenticator (security key) in the browser-based Duo prompt, but not for RADIUS/LDAP.
Duo, not DUO.
