I try to use a RV130 router to create a 6rd tunnel for IPv6 traffic on WAN port. Unfortunately the configuration web page for IPv6 tunneling is accessible but all is grey. It's impossible to select 6rd mode or modify other parameters on this configuration web page.
Is 6rd tunneling mode working on this product RV130 or is it necessary to use a RV130W to be able to configure 6rd tunnel?
I am using the last firmware version 1.0.3.22.
Thanks in advance for your answer
