RV130W Wireless-N VPN Firewall
vmihailescu_c
I have bought this router, in principal, thinking that it will help me to setup different site-to-site VPNs. Had troubles but finally worked.
In the same time I setup the wireless to use WPA2-Entreprise with radius. It works but there are no accounting packets sent by the NAS (the RV130W) to the radius server. Checked on port 1812: I have packets (it is normal - it works); but checked on port 1813: nothing/no packets sent by NAS (the RV130W)
My question: is the RV130W supporting this feature?
Thanks.
Michal Bruncko
Level 4
Level 4
I am pretty sure it doesn't support. RADIUS Accounting is considered enterprise function which is a part of enterprise-class device family, but not on small business devices. also during setup of security settings for your wireless network you are asked to confirm RADIUS port, but you are not asked for RADIUS accounting port which also confirms the statement from beginning.
