ap fails to join WLC [dtls_disconnect: ERROR shutting down]
Hi.
WLC : 5508
AP : 2802
Ping is no problem.
WLC time is my current time.
The time between WLC and AP seems to be different, but does it matter?
I will attach AP and WLC logs.
What is the problem ??
-AP LOG-
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0551] CAPWAP State: Discovery
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0574] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0595] Discovery Request sent to 172.20.201.9, discovery type STATIC_CONFIG(1)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0612] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0619] Discovery Response from 172.20.201.9
May 9 04:49:16 kernel: [*05/09/2020 04:49:16.0705] Discovery Response from 172.20.201.9
May 9 04:49:26 kernel: [*05/09/2020 04:49:26.0000]
May 9 04:49:26 kernel: [*05/09/2020 04:49:26.0000] CAPWAP State: DTLS Setup
May 9 04:50:23 kernel: [*05/09/2020 04:50:23.0133] dtls_disconnect: ERROR shutting down dtls connection ...
18 Replies 18
Factory reset the AP.
@Leo Laohoo in fact, I did it. After that, I connected the AP to WLC but still doesn't adopt it.
The remaining APs that failed to join were also joined.
Since the discovery was repeated with 200.9 and 201.9, it was joined after AP Reset.
Cause not found T_T
PratishPaul87
