ASR 1002-x Password Recovery
telpageemporia1
I tried following the password recovery as outlined in https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr-1000-series-hig/asr-hig-tbl.pdf
I am using putty, I power cycled the router and used the special options menu to insert a break. I tried this four times before giving up. Each time, the router just went on booting normally. How can I bypass booting nvram and change the password?
balaji.bandi
If you have backup config and some one set "no password-recovery". it tough but it can be done also below method.
http://www.heinzulm.com/password.php
Other way is you can do factory reset and restore the config.
https://www.hardreset99.com/routers/cisco/cisco-asr-1002x-router-how-to-reset-to-factory-defaults-settings/
BB
The second link is completely useless, as the device shown in the "solution" is NOT at ASR1002X
