Bandwidth Management in WRVS4400N
mohamedxx
I need help setting up Rate Control in Bandwidth Management. It doesn't seem to work at all. I knew from some other Posts that I need to have IPS on and I do.. Is there something else I need to do.
My users are connected wirelessly to the router through three different SSIDs  and I have 3 VLANS. I need to set some limitations on two of the LANS.
Please help me find a way to get this to work..
We had the same problem. Rate Control didn't seem to work.
I discovered that after changing the rate control settings and saving these settings the router needs a reboot.
Otherwise the rate control does not work anymore and the bandwidth is not managed.
Whenever something is modified in the rate control settings you have to reboot the router.
