08-22-2012 02:43 AM
There are still some old and new issues. This should not be so at a previously highly rated router manufacturer as Cisco.
1) Please, observe, that after a firmware upgrade from 1.0.3.5 to 1.0.4.17 it was needed to delete all the access rules and create them again to make sure, they were all working We had 40+ rules and were down for some several hours until this was detected. Outbound traffic was working.
Quite frankly: this has been seen before and why has Cisco not addressed this ? A smooth upgrade is expected by the customers.
2) The firmware is released with a reissued certificate with the same serial number.
This is bad practice and should simply not happen
It is preventing access to the router from e.g. the Firefox browser.
Old Certificate:
Data:
Version: 4 (0x3)
Serial Number: 14872231 (0xe2eea7)
Signature Algorithm: sha1WithRSAEncryption
Issuer: CN=588D09E2EEA7, OU=RV220W, O=Cisco Systems, Inc., C=US
Validity
Not Before: Mar 13 02:40:08 2009 GMT
Not After : Mar 11 02:40:08 2019 GMT
Subject: CN=588D09E2EEA7, OU=RV220W, O=Cisco Systems, Inc., C=US
New Certificate:
Data:
Version: 3 (0x2)
Validity
Not Before: Jan 1 00:00:15 2011 GMT
Not After : Dec 29 00:00:15 2020 GMT
3) The hair-pinning problem is still not solved saticfactorily.
All access from the LAN using public IP-adresses have the internal IP address of the router as the source address
I have not tested extensively yet, but at least now the IPv6 tunnel does not have to be restablished after a reboot and the NTP time settings seem to have been fixed.
08-22-2012 05:17 AM
Just some info for other users...
If you are deploying any update to a live system then you should either NOT upgrade untill all facts are known or you have run a test against some devices already. what happens if your router fails? do you have a spare? if so test the upgrade on that. if you dont have a spare then the live system is dead until a replacement is gained.
Personally the amount of changes on this firmware update should really make a full reset before/after the upgrade.
I'll list the known changes here in a moment.
Anyway just my two cents worth....
Regards Simon
08-22-2012 05:28 AM
Yep, that's the right way to do it. Just blame the customer and assume no responsibility for bad craftmanship.
04-17-2025 02:25 PM
It's frustrating when companies just push the blame onto customers instead of owning up to poor craftsmanship. Accountability is key to building trust and loyalty. Hopefully, this approach changes for the better!
08-22-2012 05:40 AM
SPR Cisco CDET Description
30606 Dnsmasq process not running after uploading customer configuration
CSCua79476 Summary:upgrading from fw 1.0.3.5 to fw 1.0.4.15 causes connection issue where router becomes inaccessible
32569 DHCP option 150 is not getting configured in the backend and device is not responding for DHCP option 150 request from client.
22224 Device is accepting 64 characters for password field in 'change password' page.
23288 Validation of meridian field is not proper in wireless active time page, when both the start and stop
24788 CSCtn81241 GUI is showing blank page when user try to login to the device using IPv6 address with I.E. browser
25252 Problem routing TCP traffic in VPN(SSLVPN Over IPSEC)
26009 CSCtr39253 Need to allow user to upload self signed certificate in both self and trusted area.
26304 Unwanted error message observed when we click back button in wireless->edit security mode page
29213 In the system summary page, in the wireless section there is a profile name column present
29222 After operation succeeded message navigation warning message should not be observed in wireless secur
29768 Able to see inverted question mark(?) before the string in content filtering page.
29997 In the help pages "contents" heading is not completely displayed with Firefox browser
30013 SSL VPN Client portal,ipv4/ipv6 routing tables display,output of ping/traceroute/lookup help pages ar
30014 Go button is not working in all the help pages.
31251 CSCtz38609 Inbound rules are getting flushed automatically with the customer provided configuration
31362 Inbound firewall rules based on portforwarding rules are not getting up in the backened with customer
31458 No Reorder button found in IPv6 access rules page
31480 There is no provision to enable logging based on severity for Protectlink Facility in Add/Edit Loggin
31561 Device is not setting Dyndns account update after Dyndns update period is completed
31836 When DST for Central European Time is selected, then time is advanced by 7 hours instead of advancing
31995 Memory percentage is not shown accurately in Dashboard page.
32097 Unable to establish Quick VPN tunnel from Windows XP 32bit host.
32289 Unable to establish Quick VPN tunnel after changing password from the client.
32428 "i8HTMl missing" message is observed, in vpn users page
32542 Unable to connect wireless clients to the WPA/WPA2 configured Access points in B/G mixed mode
32796 Support to generate self sign certificate within the router
32868 issue related to related to the HREF link in OLH pages
21593 CSCto46996 PPTP clients connected to device are not shown in VPN connection status page.
24792 CSCtr91709 / CSCtq92193 PPTP connection remains active after PPTP user is disabled/deleted in the device.
27582 CSCtt85240 Serial number for the VPN users on next page restart at 1 instead of 11
29336 Device is not redirecting to the last screen displayed before logout after session expire.
29345 Observed page with login fields greyed out when trying to access non existent portal
29346 Observed page with login fields greyed out when trying to access portal with no user on it
29397 Lan Static Routes Functionality is not Working when inter vlan routing is disabled.
30001 In SSLVPN client portal page, tooltips should be displayed in the particular language instead of English
30003 Special/weird characters are observed in SSL VPN Client portal page.
30011 Blocked to login by Admin, message was displayed in English language only
30015 Access denied to this webpage message page's look and feel is not good
30198 By Default "Blocked to login by Admin" message is not shown for guest user
30195 Wireless LED is glowing after reboot even if radio is disabled.
30576 Localization changes listed by Cisco in system summary, dashboard and radvd page, available lan host page.
04/04/2012
Latest Firmware- 1.0.4.11
19950 CSCtj57051 Entity MIB (RFC 2723) is to be supported as per Software baseline spec from Cisco
20211 CSCtj78178 Reset statistic counters
22412 User not able to delete logging policy once used in remote logging page.
24645 Default date on RV Series should be 2011
25360 CSCtr18462 Able to scan SSID and Wireless LED is glowing even if radio interface is disabled
25499 Typo in tooltips on VPN users page
25610 PPTP users can access a router that has management interface disabled.
26254 After deleting the vlan's, Still we can see upnp process running on used vlan's
26281 Bonjour page uniqueness (all vlan entries are not getting grayed out when bonjour disable)
27289 CSCts95836 wan traffic metering is not working if monthly limit is set as large value(3GB)
29248 No validation in i
29310 Traffic is not fallowing ipv6 firewall rules added with source or destination as range
29718 There is an unwanted symbol present at the bottom in the add firewall rule page
29816 Enhancement to add Static DNS for PPPoE profiles
29998 SSLVPN policy status is displayed in English language though added using other language
30006 Got $|tr Strings["11383"] or 'i18nHTMLMising'|$ when trying to add intervlan firewall rule with source and destination as same vlan for all languages except english .
30008 In French Language, We are able to see 3 vlans instead of 2(available vlans) for destination vlan name in access rule page
30012 Observed special characters in login page(password,Login) for Spanish Language
30020 "Tunnel" word should change as per the language selected
30022 Letter on the buttons got truncated in Dutch,Italian,Spanish,French languages
02/24/2012
Latest Firmware- 1.0.4.6
29335 Device is showing html error message in approved urls edit page(protectlink).
22178 Password Aging page is missing
12637 Language Selection support is not yet added
24778 Leaking RIP packets to WAN in gateway mode
24537 Windows 7 64 machine giving security warning for valid digital certification to virtual passage driver and SSL binariers
29276 GUI is displaying "i8html missing" when admin user try to configure DMZ
The following changes are introduced in MR2
1. IPv6 Firewall support
2. Inter- VLAN Firewall support
3. Boot time optimizations
4. VLAN optimizations
5. CIAM Alerts fixes
6. Localization support
10/10/2011
Latest Firmware- 1.0.3.5
22336 SSL VPN tunnel not establishing with Linux client (java version 6 update 24 and 25) and Mac OSX client
27026 Need to add zero offset in time zone page for dst offset
27045 ntp configuration issue in RV220W firmware 1.0.3.4
22472 Guests should not be able to view admin tab
20205 Incorrect default Channel value
Regards Simon
http://www.linksysinfo.org
08-22-2012 11:14 PM
Firmware- 1.0.4.17, full reset
Sometimes GUI do not respond (not being able to load).
For example, right after logging.
08-22-2012 08:59 AM
I really have to recreate all of my access rules ?
I still have 3 of those routers !
I aslo cant believe they still have hair-pinning problem !
08-22-2012 01:41 PM
Am i correct in saying that the so called hairpining problem is just that Cisco have not added this as a feature?
08-22-2012 02:13 PM
Any cheap router is supporting this, so it should rather be considered basic router functionality than an optional feature.
08-22-2012 02:20 PM
at first, it didnt work, and then they let me use a beta version (last year, had to call them) and it worked well. And then a new official firmware came out and it didnt worked again.
I made the mistake to delete the beta version I had, of course...
So now all my users whith a laptop need to use different shortcuts to access our servers according to where they are (in or out the office).
Hair-pinning is a pretty basic feature, we shouldnt even talk about it IMO. I bought 4 of these routers, still using 3 but you can be sure I wont replace them with Ciscos.
08-22-2012 02:39 PM
Well, actually it does work when you are having an access rule for each port used, but the weird thing is, that the source address of the request is the LAN router address making it impossible to act based on which IP-addresses the request is originating.
The DMZ feature is also basic router functionality, but apparently only present as a GUI checkbox, which I have not yet discovered the purpose of.
Anyway an access rule as
Always Allow Any Enabled Inbound (WAN (Internet) > LAN (Local Network)) 192.168.1.5 - 192.168.1.254
will open the LAN for access to any server port using the external IP. It seems to be working although it is not inbound WAN traffic.
However, as the external address is not mentioned in this rule, probably only sites with a single server can use it.
08-23-2012 06:26 AM
Official Release Notes:
http://www.cisco.com/en/US/docs/routers/csbr/rv220w/release/notes/rv220w_rn_1-0-4-17.pdf
Regards Simon
