Block lan access for VM
a.nef
Hi all
I'm having an RV082 which forwards ssh to a virtual machine (VMware, Bridged) having a local address, i.e. 192.168.0.xxx. I can set access rules so that only certain public IPs are allowed to access this LAN IP. Now, I would like to block all requests from that virtual machine to other clients within the LAN. I can't really figure it out what I have to do for this.
- There is a default rule in RV082 allowing all LAN to LAN traffic which I cannot disable.
- The WAN settings are of the PPPoE type, so if I try to set the DMZ to an address within the same subnet I get the message "IP Range for DMZ port must go with the Connection Type of WAN port is Static IP."
Grateful for any hints.
Andreas
0 Replies 0
