C1111-4P and C1111-8P throughput without IPSec encryption
WeiKwongOng5555
Hi, anyone got the information of C1111-4P and C1111-8P throughput without IPSec encryption? Why it is not stated in the datasheet like ISR4K?
Thank you.
7 Replies 7
balaji.bandi
Hi @balaji.bandi, can you elaborate more such as the throughput of C1111-4P and C1111-8P base unit without any license, and the throughput of the C1111-4P and C1111-8P with throughput upgrade license?
Thank you.
basic sec license  :
below table give more information :
Table 8.           Cisco 1000 Series Licenses
BB
What are the performance licenses for the ISR 1000 Series?
With the IP Base and SEC license, encrypted traffic is shaped at 50
Mbps. A performance license is needed only for encrypted traffic
of over 50 Mbps.
There are currently two types of performance
license; HSEC and IPsec Performance. The HSEC will disable the
shaper completely, whereas the IPsec Performance will only lift up
the bar on the shaper to 250 Mbps for the 8 LAN port SKUs, and to
150 Mbps for the 4 LAN port SKUs.
What I understand is that ISR 1000 does not support unencrypted traffic and that´s why they did not put on Data Sheet.
We have two kind of licensing but both of them considering encrypted VPN:  With Shape and without shape.
Hi @Flavio Miranda, thank you for the explanation.
Since you mentioned that ISR 1000 does not support unencrypted traffic, does it mean we must include the security license to support encrypted traffic?
IF 50 Mbps is enough for you,  dont.
Thank you for the explanation!
