Can't "hairpin" with RV180 Small Biz Router - how to achieve?
ndelacretaz
Community Member
We have 2 servers in our LAN set up via One-to-One NAT to accept WAN calls to 2 static IP addresses.  This works fine.
What we cannot do is: access various calendar and web forms on these 2 servers from within our LAN (thought they work fine outside the LAN).  Attempts to call these pages/services from within the LAN directs users to the router's admin login page.
My understanding is that this model does not support "hairpinning" (essentially leaving the LAN and coming back in via the WAN).
What is the best way to achieve seamless access regardless of whether the user is within the LAN or outside of it?
paolo bevilacqua
Wrong forum, post in "small business routers". You can move your posting using the Actions panel on the right.
Thanks, Paolo.  Just moved it.
Dan Miley
Level 7
Level 7
Hi Nathan,
firmware 1.0.2.6 fixed the issue reported by L2.
(reported from case 624799947)
latest is 1.0.3.10
http://software.cisco.com/download/release.html?mdfid=284005904&softwareid=282465789&release=1.0.1.9
Hope this helps,
Dan
