Capwap to mobility express on Air-AP-1852I-E-K9 not broadcasting ssid
h.kasera
I'm stuck with one of my APs not broadcasting after being configured as Mobility express.
AP model: Air-AP-1852I-E-K9
The AP was on capwap, I've upgraded it to the latest version  available on this site:
https://software.cisco.com/download/home/286285803/type/286289839/release/8.10.121.0
Aironet 1850i Access Points
Release 8.10.121.0
there were other versions in between but I went straight to the latest and I'm not sure whether that plays a role.
After conversion, the WLAN I created via command mode broadcast but anything created via the GUI doesn't broadcast.  All settings are correct and all WLANs are enabled.  I've also confirmed this via command mode:  WLAN summary
But,  for some reason,  after resetting the device,  none of the SSIDs are being broadcast,  whether it's created in command mode or GUI,  am I missing something?  Basic changes on the GUI and command mode works perfectly,  such as password change on the GUI end.
0 Replies 0
