06-15-2020 03:14 AM
Is there any way on the cisco RV134 changing the max UDP timeout from 360?
The other RV range we are able to change this to much higher.
We are having issues with VOIP phones as the timeout needs to be higher then 360.
06-15-2020 10:23 AM
- Check if this thread can help you :
https://community.cisco.com/t5/small-business-routers/value-timeout-udp-session-rv320/td-p/2716258
M.
06-15-2020 05:31 PM
Thanks, but that doesn't help as the max UDP 360 on the RV134 and we need it higher then that for the voip phone to function correctly.
