04-12-2018 01:44 PM - edited 03-21-2019 11:08 AM
Hi guys.
My problem is with my new 1921 router.
GE0/0 192.168.0.253 255.255.255.0
GE0/1 192.168.1.253 255.255.255.0
2 PCs directly connected
to 0/0 192.168.0.1
to 0/1 192.168.1.1
Both side can't comunicate each other. I can ping router interface. From router console i can ping both machines, but cannot ping from one pc to other. It is my first cisco console manage router. Maybe i've made something wrong. is there any monitor to check online packets.
I've checked same conf on cisco packet tracer (router 1941) and everything works fine.
There is no access-lists yet.
Config
Current configuration : 1173 bytes
! Last configuration change at 22:38:00 UTC Thu Apr 12 2018
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FCZ2210B0GG
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.253 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.1.253 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
password *********
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
--routing
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet0/0
L 192.168.0.253/32 is directly connected, GigabitEthernet0/0
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/1
L 192.168.1.253/32 is directly connected, GigabitEthernet0/1
Thanks a lot
Solved! Go to Solution.
04-17-2018 12:20 PM
04-12-2018 07:42 PM
04-12-2018 11:09 PM
Hellow
PC1 GW 192.168.0.253
PC2 GW 192.168.1.253
Yes I can ping both router interfaces from both pc's
04-13-2018 06:22 AM
04-13-2018 08:28 AM
Router IP TRAFIC INTERFACE during ping.
13 no route ?
GigabitEthernet0/0 IP-IF statistics :
Rcvd: 16 total, 1086 total_bytes
0 format errors, 0 hop count exceeded
0 bad header, 13 no route
0 bad destination, 0 not a router
0 no protocol, 0 truncated
0 forwarded
0 fragments, 0 total reassembled
0 reassembly timeouts, 0 reassembly failures
0 discards, 3 delivers
Sent: 13 total, 728 total_bytes 0 discards
13 generated, 0 forwarded
0 fragmented into, 0 fragments, 0 failed
Mcast: 0 received, 0 received bytes
0 sent, 0 sent bytes
Bcast: 5 received, 0 sent
Firewall excluded (both ip's reposnding from routers console)
There is no icmp packets in wireshark when pinging from PC to PC
I think that problem is with packets forwarding, so maybe arp table is incorect, maybe no acl or empy access-list is deny by default. I have no idea.
04-16-2018 05:32 AM
I've added gateway (ip route 0.0.0.0 0.0.0.0 "adress" metric)
PC with same network as gateway is passing, the other one has no internet access.
04-17-2018 12:20 PM
04-17-2018 01:27 PM
I'm realy greatful for your help and i admire you profesionalism
Take care
Jakub
04-17-2018 01:29 PM
