CISCO 2921 - RV042 G2G VPN Issue
baligh.gehad
Dear All,
Hope everything is good at your ends,
I’ve been looking for the past 7 days for a solution with no luck that’s why I’m posting in here hoping you can help me out.
Well, I have 2 physical locations as Main and Branch
Main:
I've CISCO 2921 as a Gateway with 100.100.100.100 as a Static Public IP and 192.168.1.0/24 as a Local Private IP
Branch:
I've CISCO RV042 as a Gateway with 200.200.200.200 as a Static IP and 192.168.2.0/24 as a Local Private IP
The plan is connecting both sites permanent so I can use IP phones, Cameras, Printers… etc in Branch
What I’ve done based on the cisco practice in the Branch RV042 router is shown as 1.jpg, 2.jpg, 3.jpg in attchment
And I connected SSH to the Main Cisco 2921 and did the below
Router(config)#crypto isakmp policy 1
Router(config-isakmp)#authentication pre-share
Router(config)#crypto isakmp key ************** address 200.200.200.200
Router(config)#access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
Router(config)#crypto ipsec transform-set myset esp-aes esp-sha-hmac
Router(config)#crypto map Main_Branch 10 ipsec-isakmp
Router(config-crypto-map)#set transform-set myset
Router(config-crypto-map)#set peer 200.200.200.200
Router(config-crypto-map)#match address 100
Router(config)#interface gigabitethernet 0/0 (THIS IS THE 100.100.100.100 interface)
Router(config-if)#crypto map myset
and I'm not able to ping from 192.168.1.0 to 192.168.2.0
In the Branch RV042 Router I've tried the below
  • Test VPN... If I clicked (Connect.... wait....Connect) nothing happen
  • Diagnostic Ping 192.168.1.0---> Packet drops
  • Log files indicate ---> (g2gips0) #163: [Tunnel Established] ISAKMP SA established
  • Disable Firewall
  • Advancing Routing, Created the below routing
  1. Destination IP: 192.168.1.0
  2. Subnet Mask : 255.255.255.0
  3. Default Gateway : 100.100.100.100
  4. Hop Count: 3
  5. Interface: WAN1 (WHICH IS 200.200.200.200)
Also with no luck
Also in the Main Router I've tried this
Router#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
100.100.100.100 200.200.200.200 QM_IDLE 1702 ACTIVE
100.100.100.100 200.200.200.200 QM_IDLE 1615 ACTIVE
IPv6 Crypto ISAKMP SA
Router#show crypto ipsec sa
No SAs found
Router#show crypto map
Crypto Map IPv4 "Main_Branch" 10 ipsec-isakmp
        Peer = 200.200.200.200
        Extended IP access list 100
            access-list 100 permit ip any any
            access-list 100 permit ip 0.0.0.0 255.255.255.0 0.0.0.0 255.255.255.0
        Security association lifetime: 4608000 kilobytes/3600 seconds
        Responder-Only (Y/N): N
        PFS (Y/N): Y
        DH group:  group1
        Transform sets={
                myset:  { esp-aes esp-sha-hmac  } ,
        Interfaces using crypto map Main_Branch:
Router#show crypto isakmp policy
Global IKE policy
Protection suite of priority 1
        encryption algorithm:   Three key triple DES
        hash algorithm:         Secure Hash Standard
        authentication method:  Pre-Shared Key
        Diffie-Hellman group:   #1 (768 bit)
        lifetime:               28800 seconds, no volume limit
Honestly I've no idea from where I should start, and for the past two days I've trying google searching everything with no luck
Please help me out
Awaiting your reply
Thanks in advance
rvarelac
Level 7
Level 7
Hi baligh.gehad
I would enable the following debugs on the Cisco 2921 in order collect more information ( you need to start intersting traffic in order to trigger the debugs)
* Debug crypto isakmp
*Debug crypto ipsec
Based on the current output, seems it a problem of phase 2 only , please check the ACL on evey site is configured and mirrored properly.
Hope it helps
-Randy-
Dear rvarelac,
Many thx for your reply,
I used both
* debug crypto isakmp
* debug crypto ipsec
and it says debug is on and no output.. How I can get output to narrow down the issue?
On my 2921 I've the following ACL
    10 permit ip any any (1126332 matches)
    30 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
And on the other RV042 I disabled the firewall, so there is no rules or ACL to create and it should accept all traffic
Awaiting your reply
Hi baligh.gehad
The VPN ACL needs to match on both sides, we can't have the current configuration.
For example if you  have configured on the 2921 the ACL "permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255"   on the RV device should exist the  mirrored ACL  "permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255" under the VPN configuration.
I would remove the any any statement and create the ACLs as above.
-Randy-
Dear rvarelac, Thanks again for your reply, I do appreciate If I removed the any any I lose internet in all hosts within Main office and the RV router has Firewall - Access Rule... LAN from any any is by default cannot change the entry what I've done on the RV that I created a rule on the LAN interface to allow 192.168.2.0 to 192.168.1.0 and another entry for WAN any to any so I match the 2921 Still not working :((
