Cisco C891F unable to telnet/ssh to WAN port. connection refused.
Team,
I'm unable to remotely (WAN interface) access this Cisco C891F router using the underneath config.
telnet and ssh both works using the LAN interface. the error message is get is "Connections refused"
With debug ip packet i do see an RST packet as a response to the incoming telnet request packet.
Current configuration : 9161 bytes
! Last configuration change at 15:45:37 CET Fri Oct 30 2015 by support
! NVRAM config last updated at 16:27:05 CET Fri Oct 30 2015 by support
version 15.3
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname ROUTER
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 65355
enable secret 5 $1$I7QP$kidZ3cWzV0j2RAQ7KIJPz0
enable password <…>
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
clock timezone CET 1 0
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
ip dhcp excluded-address 192.168.2.1 192.168.2.69
ip dhcp excluded-address 192.168.2.200 192.168.2.254
ip dhcp pool 1
network 192.168.2.0 255.255.255.0
domain-name ROUTER.nl
dns-server 194.109.6.66 8.8.8.8 194.109.9.99
default-router 192.168.2.254
lease 0 4
ip domain name ROUTER.nl
ip name-server 194.109.6.66
ip name-server 194.109.9.99
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FCZ1939917Z
username support privilege 15 password <…>
username a3sup privilege 15 password <…>
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
shutdown
interface GigabitEthernet3
no ip address
shutdown
interface GigabitEthernet4
no ip address
shutdown
interface GigabitEthernet5
no ip address
shutdown
interface GigabitEthernet6
no ip address
shutdown
interface GigabitEthernet7
no ip address
shutdown
interface GigabitEthernet8
description verbinding met xs4all.
mtu 1492
bandwidth 500000
no ip address
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet8.4
description VLAN ID 4 is for IPTV
encapsulation dot1Q 4
interface GigabitEthernet8.6
description VLAN ID 6 is for Internet (pppoe) 213.238.215.201
encapsulation dot1Q 6
pppoe enable group global
pppoe-client dial-pool-number 2
interface GigabitEthernet8.7
description VLAN ID 7 is for VoIP.
encapsulation dot1Q 7
interface Vlan1
description Netwerk ROUTER.nl
ip address 192.168.2.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Vlan6
no ip address
load-interval 30
pppoe-client dial-pool-number 1
interface Async3
no ip address
encapsulation slip
interface Dialer2
description Verbinding met xs4all. 213.238.215.201/32
mtu 1492
ip address negotiated previous
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 2
dialer-group 1
ppp authentication pap callin
ppp pap sent-username FB7490@xs4all.nl password 7 025756085F
ppp ipcp address accept
no cdp enable
crypto map vdAAmap
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer2 overload
ip nat inside source static tcp 192.168.2.51 8000 213.238.215.201 8000 extendable
ip nat inside source static tcp 192.168.2.250 9100 213.238.215.201 9100 extendable
ip route 0.0.0.0 0.0.0.0 Dialer2
dialer-list 1 protocol ip permit
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner login ^C
Authorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 30 0
privilege level 15
transport input telnet ssh
transport output none
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
ntp server 129.250.35.251
ntp server 64.99.80.30
end
ROUTER#
I'm doing something wrong, but I can't figure out what..
Any help is highly appreciated.
Thanks in advance, Willem
Mark Malone
Try turn off the aaa for a minute no aaa new-model
set standard username/password ---username Willem secret xxxxx
Then under line vty 0 4 apply ----login local
thsat should work for you , did you generate crypto keys for the ssh ?
Mark,,
I have done as suggested.. No results..I believe it is related to either a NAT or routing issue (bug).
I have also delete the vlan 6 interface as that one was not required any more.
I have about same config, a little different router, older IOS and that one works.
Still looking for a solution.
We ran into bug CSCup75103.
Symptom:
On IOS upgrade to 153-3.M2.bin & onwards, we cannot telnet/ssh the router where nat is configured.
Conditions:
This problem only exists if we have nat entry configured using ip which also exist on an interface, i.e
Workaround:
change the above statement to use interface instead of ip address, i.e
ip nat inside source static tcp interface
Upgrade to 15.4(3)M4  solved the problem.
