Cisco 527W - How to disable LAN interfaces
aravinda099
Hi all,
Just wanting to know if there is a way to disable unused LAN interfaces of these Cisco 527W routers. Looking through the configuration interface it doesnt seem to have an option for this.
Also I am having trouble logging into the router via SSH or Telent . When I put the password in it says "access denied" . But password works for the web interface..
Thanks...
For my experience, no way at the moment.
Regards.
5 Replies 5
aravinda099
Any help would be appreciated ... Thanks...
Can anyone help please ? Thanks.
Regards.
Thanks Daniele.
Any idea about not connecting via SSH or Telnet ?
I noticed same thing. In my opinion Telnet or SSH are used only for Cisco support. You can try to contact your Small Business Support and ask for a feature request.
Regards.
