Cisco c1111- 8p
Monti1800
Hello Everyone,
Reaching out to see if its possible to set up high availability on this router with the same ip address with 2 interfaces. Basically if we have some sort of hardware failure we are wanting the failover to switch to the other port. Router "Cisco c1111- 8p"
We would want g0/0/0 to be the primary and g0/0/1 to be the failover.
Thanks in advance.
you cannot configure same IP for two interfaces in same router.
Good luck
KB
