Cisco Router RV160W console port is not working
arkan
I'm trying to connect through the console port with the following data from minicome
Which it means:
Speed: 9600
Data Bits: 8
Stop Bits: 1
Parity: None
Flow Control: XON/XOFF
And I'm getting nothing for these settings, also I've tried 115200 speed and it did not work.
This is what I'm getting:
If I click 'Enter', or anything, there is nothing to happen.
marce1000
 - Check this thread (guess bad news...) :
           https://community.cisco.com/t5/small-business-routers/access-cli-on-rv160w/td-p/4033101
 M.
marce1000
 M.
Thank you @marce1000 , this is sad, because in this situation I will need to buy Raspberry Pi 4 and to use it as a vpn as I've done it with my other network using TP-Link router with Raspberry Pi 4 in order to power on lan my servers.
And the problem that I have with current router (RV160W) that I can access my network through OpenVPN but the problem I think it's dropping the broadcast packets.
I have this problem on Linux (Raspberry Pi 4) and it only work if I set the following (tun0 is my VPN interface) and also turn wake on lan from BIOS:
  • net.ipv4.conf.all.bc_forwarding=1
  • net.ipv4.conf.tun0.bc_forwarding=1
This worked for me and I can turn on my servers from my phone when I'm outside of home (using mobile data or external wifi network).
Arkan
