Cisco RV042 Router automatically Restart every 1 minutes
Maria Joseph R
Dear Sir,
Cisco RV042 Small Business router is automatically Restart every 1 minutes. Kindly give the solution to rectify the problem
Maria Joseph. R
75 Replies 75
Mark Elsen
             - Use latest firmware (if applicable)
 M.
DawidKiedio9227
we have the same issue with latest firmware 4.2.3.14. do we have any recommended solution for that?
looks like a global problem with this model. anyone have any solution?
mbleamer1
We have the same issue with both the RV042 and RV042G models.  The issue just started today, but we have at least a dozen routers with this issue.  All are using the latest firmware, v4.2.3.14.  Hoping someone has a valid suggestion, or at least an answer on why/how this issue suddenly affected so many devices.
Mike
SergioA
We have same issue on 7 rv042. Any solution?
manueldobarro
In my case, the device restarts all the time and does not give rise to a firmware upgrade, even with the interfaces turned off or with all the features low. Changing the date did not work either to stabilize it. I am with 17 RV042 with the same problem.
SergioA
In my case I lose Lan and Wan connectivity after 1 minute. It hangs totally and I have to turn it off and on.
There is no time to update the Firmware. Same in 7 rv042. Tested with Wan disconnected, and new power supplies. Tested with Wan disconnected, and new power supplies
DanielBernal
We have the same problem with 7 RV042G, the issue starts today too.
We need solution
We have 20 rv42g in production, and last week we had to replace 10, this is crazy. we need a solution. cisco.
Martin Aleksandrov
This has been addressed to Cisco TAC engineers and is currently being investigating. Please go ahead and open a ticket by contacting any of the phones below:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
I have been told by Cisco support that we first need to renew our support for these devices before they can open a ticket.
So no.
biuro spin
Does anyone know the solution to this problem?
rv042g ,firmware 4.2.3.14.
MT
biuro spin
hello,
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-rv-overflow-ghZP68yj
after factory reset my router keeps rebooting every 60 seconds.
does anyone know how to work around this problem?
