Cisco RV082 to ASA 5510 tunnel freezes after 8 hours.
james.blish
I have a RV082 that has an issue keeping an IPSEC Gateway to Gateway VPN running from itself to our ASA 5510.
At 8 hours of connectivity (I can almost set a clock to it) the Tunnel will say it is connected on the RV082 but on the ASA 5510 the tunnel is not up.
If I click on disconnect on the RV082 under the VPN Summary page things will come back up. from the ASA 5510 side there is nothing I can do to get things back (ping inside "vpn network" or even trying to make a connection to a networked VPN machine).
To make things more complicated I have another VPN on the RV082 to a PIX 506e that works with no issues. I also have another RV082 at another location with the same settings that keeps its tunnel with the ASA 5510 with out any issue.
Some things I have tried to try and fix the issue are:
I upgrade the firmware on the Rv082 V3 from 4.0.0.7-tm (what it was shipped with) to 4.1.1.01-sp) - This seemed to have no effect.
on the RV082 I have changed the MTU from automatic to 1428 and 1452 - all this does is make the connection to the PIX 506e unstable like it is for the ASA 5510 I have changed this back to automatic.
since the time of stability seems to be 8 hours I have changed the "Phase 1 SA life time" and "Phase 2 SA life time" to 28800 both at the same time and individually - This seemed to have no effect.
The current configuration on the RV082 are:
Local security gateway type: IP Only
IP address: (local ISP provided static IP address)
Local security group type: subnet
IP address: 192.168.30.0
subnetmask: 255.255.255.0
Remote security gateway type: IP only
IP address: Remote address provided by ISP
Remote Security type: Subnet
IP address: 192.168.26.0
subnet mask: 255.255.255.0
Keying mode: IKE with Preshared key
Phase 1 DH Group: Group 2 - 1024 bit
Phase 1 Encryption: 3DES
Phase 1 Authorentication: MD5
PHase 1 SA Life Time: 86400
Perfect forward secrecy: is not checked.
Phase 2 DH Group: Group 2 - 1024 bit
Phase 2 Encryption: 3DES
phase 2 Authentication: MD5
Phase 2 SA Life Time: 86400
Preshared key: <shared-key>
Minimum Preshared Key Complexity: is checked
Preshared Key Strength meter: goes to 2 green boxes.
advanced setting nothing is set up.
ASA IPSEC related settings for this VPN:
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-SHA esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ipsec df-bit clear-df inside
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map internet_map 7 match address internet_cryptomap_7
crypto map internet_map 7 set peer (Static_IP_ADDRESS)
crypto map internet_map 7 set transform-set ESP-3DES-MD5
crypto map internet_map 7 set reverse-route
crypto isakmp enable internet
crypto isakmp policy 4
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 5
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
tunnel-group (Static_IP_ADDRESS) type ipsec-l2l
tunnel-group (Static_IP_ADDRESS) ipsec-attributes
pre-shared-key <shared-key>
thanks in advance.
19 Replies 19
rocater
Level 3
Level 3
Hello Jim,
Given the time problem I would say it is the lifetime that is causing the issue. I know you mentioned changing the lifetime settings as well, but there is still this line-
"crypto ipsec security-association lifetime seconds 28800"
I wish there was more I could do for you but my ASA knowledge is limited.
Jim,
What is the Crypto map that is assigned to the outside (internet) interface? Verify the ASA dosn't have PFS turned on, because it is on by default.
hope this helps
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
Thank you Robert,
The problem is that I don't want to change the ASA it has 4 working VPN's on it already and if i make a change on the ASA i could be ruining those stable VPN's you wouldn't by any chance know if the:
corrilates with Phase 1 or Phase 2 as defined by the RV082 (I have been assuming that it is phase 1 but my brain has become broken on this issue)
Hello Randy,
for the default crypto map I believe this is it:
I see that PFS is turned on I will try adjusting that this evening/weekend on the RV082 (again don't want to make sweeping changes on the ASA as it is the more important and stable piece in this) and let you know how things go.
i've changed the phase 1 to 28800 again we will see if this makes it.
after the change the colapse happened at 6 hours instead of 8. change phase 1 back to 86400 and phase 2 to 28800. also tried pfs with 86400 on both phases and still no connection can be made.
when pfs is checked the error I see that I believe is the issue for connectivity is
#171: Sending encrypted notification NO_PROPOSAL_CHOSEN to (STATIC_IP_ADDRESS):500
Deleteing connection
any other ideas?
will notify again when tunnel colapses again or if it is stable with phase 2 at 28800
had crash with 28800 for phase 2 and put it for both phases on the RV082 still 8 hour drops. I changed the advanced to "agressive mode" the tunnel stayed up for 18 hours with that but after colapse could not connect again until agressive mode was turned off.
Any other ideas?
Jim,
Is PFS on for Phase 2 on the ASA? how about the RV? What DH group on both? it looks like group1 on the ASA.
Does phase 2 ever rekey correctly?
What is the lifetime for phase 1?
Does Phase 1 stay connected?
what happens if you run a constant ping through the tunnel, does it stay up longer than the 8 hours?
Are the Date and times correct on both devices?
Can you provide the settings of the RV?
Randy Manthey
Hello Randy,
For PFS on the ASA I believe it is on phase 1:
on the RV it isn't turned on at all when it is checked the VPN tunnel never connects.
I have no idea if the phase 2 is ever rekeyed if you tell me how I can check that I will look.
Lifetime for phase 1 is 28800 if I am reading correctly:
on the RV if I set this uptime seems to drop to 5 hours so currently it is set at 86400
phase 1 seems to stay connected on both devices I am not sure how to check this as well.
If I do a constant ping from the asa to RV (and the other way around) the tunnel still drops at 8 hours. In fact the tunnel will go down in the middle of the day if I do not premtively drop it and bring it up while people are using the connection.
the dates on both systems are the same and use NTP to stay in check. the RV082 has the daylight savings pieces put in.
Is there a way to scrub the RV's export and I will post it but with a straight export it is semi encoded and I would rather not have my passwords and ip addresses posted to the internet if I could avoid it.
Jim,
I would recommend you call into the 1866-606-1866 and create a case so your configuration can remain confidential.
On the ASA CLI you could run:
Show crypto isakmp sa      - phase 1
show crypto ipsec sa         - phase 2
Just the logs on the RV is the only place to see if it is attempting to re-key.
Randy Manthey
Hello Randy,
from the ASA:
4   IKE Peer: (IP address)
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
Show crypto ipsec sa
from the RV there is nothing that happens before the crash for 4 hours (crash happened at 20:55)
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: ignoring Vendor ID payload [XAUTH]
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: received Vendor ID payload [Dead Peer Detection]
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: ignoring Vendor ID payload [Cisco-Unity]
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: ignoring Vendor ID payload [e3c2cddc6781d12ba5d08759c31a6d90]
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: [Tunnel Negotiation Info] <<< Initiator Received Main Mode 4th packet
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: [Tunnel Negotiation Info] >>> Initiator Send Main Mode 5th packet
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: [Tunnel Negotiation Info] >>> Initiator Receive Main Mode 6th packet
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: Peer ID is ID_IPV4_ADDR: ipaddress
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: [Tunnel Negotiation Info] Main Mode Phase 1 SA Established
Apr 23 17:40:21 2012 VPN Log (g2gips0) #2099: ISAKMP SA established
Apr 23 17:41:11 2012 VPN Log (g2gips0) #2088: received Delete SA payload: deleting ISAKMP State #2088
Apr 23 21:07:49 2012 System Log HTTP Basic authentication success for user: admin
Hello Jim,
It looks like Phase 1 keeps rekeying. Does the RV082 have a public or private IP address on the WAN? Do you have NAT-T setup on the VPN?
If you are using a public IP is it static or DHCP?
RV?
ASA?
Can you set the Vendor-ID on the ASA to its outside IP address?
If all that is fine or can be done. I would recommend trying to turn off PFS on phase 1.
Randy Manthey
Hello Randy,
The RV has a static public IP address. (as does the ASA)
only the ASA has NAT-T working on it the RV is strictly NAT outgoing only.
I'm not sure what you mean by set the Vendor-ID on the ASA to its outside IP address.
I will try turning off the PFS on the ASA with a: "no crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1" this evening
Thank you Randy,
The removal of PFS seems to have worked the tunnel has now been up for 12 hours. after 48 hours if things are still good I will say everything is good.
Most likely some thing in the shared secret DH values are not matching when hashed.
Randy Manthey
