Cisco RV220W - Disconnect\Reconnect WAN
michael.dresser
Hi all,
I have and D-Link modem which is bridged and a PPPoA\PPPoE profile set up on the RV220W for my ADSL2+ connection.
I cannot for the life of me find anywhere in the routers config web pages to tell the modem to disconnect or reconnect the connetion to the ISP.
The reason I want this is because I need to make sure the correct signaling is sent before the connection is stopped so that the exchange doesnt see this as a drop out and reduce our line speed to compensate.
Michael.
mpyhala
Level 7
Level 7
Hi Michael,
Thank you for posting. You could uncheck "Internet Connection Requires a Log in:" and save the setting. This would change the router to DHCP instead of PPPoE and of course the connection to the modem would stop.
