Cisco RV340 & TM UNIFI Broadband
dennis
Hi All,
I'm setting up a new Cisco RV340 router for my boss house.
However, I noticed when I have configured the correct VLAN & WAN connections as per requested by ISP.
The WAN port able to obtain IP address from telco but unable to connect to internet.
The ISP router when bypassed Cisco RV340, there's no issue. Any ideas why ?
Is it possible the telco has blocked specific router to connect to their network or it's something to do with my RV340 configuration ?
Appreciate urgent help here. Stuck unable to configure internet connectivity with Telekom Malaysia UNIFI broadband.
Thanks & Regards.
Jitendra Kumar
CSCvm66202 bug.  check whether the "Network Service Detection" is enabled. then Disable it.
wan1" interface you will see the "Network Service Detection" feature settings
Default  Network-Service-Detection is enabled on wan1 (and wan2) interface
Jitendra
marce1000
 - Check logs on the RV340 when internet connection is made and or when traffic is trying to pass.
 M.
